david_bagshaw
Can't quite see how the motor is the same? This compressor is 205 litres/min or 7.2 cfm, 8 bar, only data for motor(?) is 2.5Hp, clamp meter showed nearly 14A with a stalled motor trying to start with cylinder full, didn't check while pulling the release valve which some days is the only way to get it start on not great boatyard power.
well it was from machine mart in the middle 80s, being the largest single phase unit available and supplied with a data sheet suggesting it could be used with a 13 amp plug on the end. It also struggles to get going on boat yard power on a cold day. when you think 14A at 240 v =140 A at 24 or 280 at 12, with a 100% efficient inverter( another item made by the flying pig co) the hit on the battery bank is probably not on.
