Compression testing. Is this a thing?
IanCC
14 Oct 2019
Ok, would love to do the compression test thing. Yes i have a spare injector i can adapt (i guess that means remove all internals & seal leak off hole) . But seems to me to get it to seal properly, all the other gubbins needs to go in first, copper washers, heat shield, combustion chambers. Copper washers are use once, yes i know you can heat them up but sometimes there are impurities which melt. Seems all quite problematic and borderline expensive.
Am i overthinking this?
IanCC
14 Oct 2019
Engine doesn't run perfect, so have replacement set of injectors to go in. 3gm30f doesn't start perfectly, only goes to 3600 in neutral and blows a little black smoke which i reckon is overfuelling from 25 year old injector springs having softened a little but may not be.
Would like to test compression while swapping.
bikedaft
16 Dec 2008
tayvallich
I don't get what thw decompress levers have to do with it? 😊
Run the engine. Decompress one cylinder at a time, whilst going through your tests - if decompressing one cylinder makes less of a difference than the other 2, there's your culprit.
We also have a 3gm30f. In time I will recon the injectors, rather than testing. But then it runs ok at the moment...
Good luck
IanCC
14 Oct 2019
Not a good idea, as i understand it, carbon can get wrong side of exhaust valve so sticks open to be rammed shut by compression stroke. That's why manual says loosen injector pipes.
I just want to test compression while swapping injectors. They are refurb, cost £20.
scottie
14 Nov 2001
scotland
Old fashioned crude test is loosen injector pipe one at a time will show if one is substantially worse than other in differing rev drop
just break the nut and cover in rag
but if you are feeling really curious than get proper adapter and guage to suit engine
scottie
14 Nov 2001
scotland
That ridiculously cheap check providence?
IanCC
14 Oct 2019
Pretty sure there is no such thing as a proper adapter. Much googling and reading of forums.
IanCC
14 Oct 2019
There are, depending on the kit you can get dummy injectors and adapters for glow plug holes
I have just been asked to make some adapters for use in place of Volvo Penta KBAL injectors for a customer
I don't have glow plugs, just injectors. Why are you making adapters if they can be bought off the shelf?
