Compression Test HELP
Sydison
New Member
13 Sep 2020
Im looking at purchasing a boat 330 SeaRay Sundancer and the port engine is new ( has 60 hrs on it ). I had a compression test done it and it is as follows.
Cylinder PSI
1 130
3 140
5 110
7 140
2 135
4 140
6 120
8 130
The mechanic who did the test stated since the engine was so new that the two cylinders that showed lower PSI ratings were probably not fully seated yet or broken in. Can anyone please help in clarification on this test and if there is any truth to that statement ?
I appreciate any help in advance
IMO all those are low for a 60 hour 4 stroke gasser. I'd expect to be seeing around 160psi, however they are all within tolerance and "balance"
Cylinder PSI
1 130
3 140
5 110
7 140
2 135
4 140
6 120
8 130
I’d expect to see at least 200 psi .
comp test only tells you something if there is a massive imbalance between the reading.
cylinder leakage test is the proper way to ascertain an engine condition
This was a crate motor ....Chevy 350
those who asked about the starboard engine...813 hrs on it
1-160
3-155
5-150
7-155
2-160
4-165
6-160
8-160
Presume the test was done with the engine fully up to temperature?
If you do it cold you can get low values.
I have presumed cold testing unless this was done on the water after a run which I think unlikely in the tight confines of a 330 engine bay
This was a COLD test indicating numbers under the cold testing conditions. Should a test be done when engine is at normal temp ?
Few things here.
presuming it’s the expected 5.7 vortec...a new and warm engine will be about 160 at its peak usually. If it’s cold you will only ever get a rough indication of health at best.
All I would say is that perhaps question if the engine has ever had water through it by means of a corroded manifold or similar. These are famous for have valve issues after such things and will certainly show a little low on compression if so.
Another thing that will show low compression on these are the condition of the oil. If it’s had crap quicksilver 25w40 in it, that oil can break down very quickly. Especially on carb variants if ran at idle for too long with no load on it. A prime example of why this would be the case on one engine and not the other, would be if that engine had the hot water heater tapped into it. Then the owner may have ran that engine at idle under no load for ages to get water heated.
