Companionway trim replacement advise
Stalker
2 Aug 2025
Hey everyone!
The companionway rail trim has been broken since I purchased the boat. Any suggestions on where to find a replacement? I have searched but have not found anything yet - possibly using the wrong search terms.
Any help is appreciated.
That would have been made specifically for that model of boat, so the only likely supplier would be the dealer or maker of the boat.
Trim both sides plastic to same .... cut back the 'wood' ready to replace
Then get two hardwood battens and create the L shaped by glue and pegs .... sand to required and then fix in place.
I've had to do this job on two boats ...
Trick is to alter the cosmetics so that repair appears same both sides and not as an afterthought.
Thank you all for suggestion! I was really hoping that maybe it is possible to find a ready made replacement, but seems I will have to do some self made one 🙂
