RIN
So its commissioning time and I thought this would be something I could do myself this year as the (1994) Volvo 290DP legs were taken off the boat and serviced professionally last year (as they are every two years). I thought it would just be a case of draining the oil and filling with fresh oil but I have run into 3 snags I need the advice of our forum on
Problem no1
The colour of the oil out of the two drives was different. I hope this comes across in the picure
There was also a little bit of white stuff in both samples
So is this normal? Can I just refill and carry on or do I need to throw copious amounts of pound notes at them?
Problem no2
The play in the legs which I noticed when taking the props off surprised me. There was about 3-4mm of play in the fork. Is this normal? I went around other Volvo sterndrives on the hard and some were as loose as mine, some had no play at all
Problem no3
One of the legs would not go down. The trim pump works when going up, I have removed and cleaned the two relays on the pump bracket, and then swapped them over and it still will raise but not lower. I also swapped the relays at the helm over from port to starboard and still the leg will raise but not lower. Any suggestions for what to try next?
Any advice gratefully received on all or any of these problems
Problem no1
Problem no2
Problem no3
