Colonic irrigation for saildrive
Spuddy
8 Jul 2003
Kent
I've been tussling with raw water cooling for a while. Exhast elbow needed doing but didn't sort problem. Impeller checked of course. Did the Rydlyme treatment through the block. Better but still no GLOOP GLOOP at tickover. Tthe boat settles into Medway mud at half tide ....could there be clogging in the saildrive leg inlet. Improvised the mains hose to fit the seacock and gave it a good long backflush. SUCCESS. Never come across mention of this before.
Nice one. I have heared a few reports of mussels and other critters setting up home and blocking the inlets but not mud. I expect most people dont regularly dry out their sauldrive legs into mud and those that do should flush them out occaisionally as you have done.
If this is an ongoing issue then it might be better to have a separate raw water intake with a seacock. Less likeely to get bunged up in the first place and easier to clear.
I use this to clear the saildrive
http://www.argos.co.uk/static/Brows...546/c_3/3|cat_33007546|Air+pumps|33014904.htm
Also have a separate skin fitting for Plan B
Hi Slowtack, I couldn't find that part on the Argos website. Could you give the catalogue number please?
I've fitted an inline water filter on my sail drive this summer as I got an overheat due to a bit of seaweed and
a small mussel shell in the heat exchanger. I don't have the space for the bigger type of strainer.
This the one ?
9152825_R_Z002A_UC1404877
http://www.argos.co.uk/static/Product/partNumber/9152825.htm
