nelsonmandela
The next instalment ----You may have see my posting about re-starting coelan aplication after a long time.Well its not that great news for those of you who like us thought we could just pick up where we left off.
It seems to be possible to add new coats by sanding back with 60 to 80 grit as if you where just continuing on with a normal application ( not that you can get this info from Coelan) However the problem for us is that we had used the (red) so called mahogany coloured primer since the boat is to have "natural coloured" hull.THE PROBLEM IS--that the colour changes with time --both the wood and the Coelan stain/primer or what ever it really is.
As a result If you intend to do any new work on a previously coated hull it is difficult to predict whether there will be a colour match in due course or whether you will end up with an unaceptable patch work.
The lesson for us is to do EVERTHING we can to sort the varnished areas well before they are coated up because there appears to be no going back once you have started ,until of course you have sanded the boat to nothing!!! DISPITE THIS WE THINK THIS A BRILL PRODUCTas best as we can tell, its just that the preparation is all.
