Cockpit table varnishing
cmedsailor
10 Sep 2007
East Med...
My cockpit table (see the photo) looks tired. In the past I did try sanding it with a sand paper and then applying wood varnish but results were not very good. I must say it was just a quick job though.
So what do you think I could best do? Apply some chemical stripper (a paint removal) to remove any varnish and bring it to bare wood and then what? Any ideas please?
VicS
13 Jul 2002
For solid wood I would use International Woodskin
My ply cockpit table is varnished with International Yachtpaint single pack polyurethane . Cant tell you exactly what because they keep changing the name.
but it doubles as the cabin table and stows away in the forepeak when not in use
PlankWalker
2 Feb 2010
South UK
If its all solid teak you may leave it to go silver, giving it the patio migic treatment anualy.
If its teak veneered ply then it must have a surface coating applied,
my preferance is for 3 coats of epoxy, rub down, then 5 coats of alkyd varnish, rubdown again before the last 2 coats.
Plank
Tranona
10 Nov 2007
International Woodskin. Use either a chemical stripper or a hot air gun to remove the old varnish. Go easy on the sanding of the veneer. Alternatively you might consider then using good quality teak oil and invest in a cover for the pedestal so it is only exposed when you are using the boat. This is what I have done on my new boat. Not a good idea, though if you leave it exposed as it will need frequent redoing.
ashtead
17 Jun 2008
Surrey and Gosport UK
I have used ikea oil on our table in the past which worked well but another thought migHt be seemco
I saw a lovely table on a new moody 54 ds at SIBS which showed what could be achieved with enough time
Stemar
12 Sep 2001
Oils are generally less durable than varnishes, but have the advantage that they are easy to repair if the finish is damaged. I used A Cuprinol product for outdoor furniture (can't remember which as it's on the boat) and 3 coats have proved t be pretty durable. When a freshen-up is needed, it's the work of a few minutes to wipe another coat on.
+1 for the cover, whatever you decide to use. Better still, take a deep breath and order a cockpit tent. Mine is probably the best single investment I've made for Jissel. You'll find you use the table twice as much!
martinriches
8 Jun 2005
London
As far as getting the old varnish off, I am using a heat gun and scraper on my handrails at that moment and I can't imagine anything easier. After I used 100 grit sandpaper in a palm sander then finished off with 180 grit by hand. Very pleased with the result.
Martin
