CO32, Sadler 32, then what??
SAWDOC
24 Feb 2008
Ireland West Coast
It is often written that the Sadler 32 was a design progression on the Contessa 32. Has anything better come along since in terms of seaworthiness, speed and comfort?
Yes. The Starlight 35 is in many ways a modern incarnation of the Contessa. Slim hull, beautifully balanced, tough as old boots, sails very well but definitely a cruiser racer rather than an outright racer.
Well the designer's own boat progression went Co26, Co32, Sadler 32, Contest 43. The Contest was not his design, but he went off RTW in that one. Still at least it could be abbreviated to Co43?:)
Lots of boats have more speed.
Seaworthiness is multi-faceted.
A lot of C032's are not as seaworthy as they should be because the gear is all worn out, this applies equally to any aging boat with a limited maintenance budget or boat with cheap gear.
Comfort is a matter of opinion, perhaps you trade the comfortabe motion of an older design for the comfort of more space etc.
In terms of value for money, the Contessa gives only a moderate return on these three criteria.
But they do have class racing, and some people like the look of them....
Blimey, makes mine positively anorexic.
An accusation which has never been levelled at you:).
I've never rated CO 32's, wet, not particularly fast (tho close winded) and accommodation not suitable for normal sized people. Sadler slightly better but only on the margins.
Rightly IMO, sailing has moved on from being a branch of Adventure Training, with it's concomitant discomforts, to a pleasurable leisure pursuit.
(Ice in my G&T and pop the paella in the microwave).
Some MABs have Microwaves ;)
You have all over looked the best of the lot .
The Westerly Fulmar.
Similar value ,same size but faster, more comfortable and not as wet to windward.
Cor, you're brave, challenging the old icons and the "old designs are better than new" principle !
Next you will be suggesting one of these new fangled German BMW's are better than a Morris Minor
PS Agre with subsequent post that Fulmar was the next progression at this size
You're right but its very odd because she looks a lot slimmer than the Bennies etc moored along the pontoon. Possibly its the difference between max beam and beam at the transom. Either way its a really well balanced hull and all the boat tests at the time said so. Totally failed ever to get mine to round up.
beniblobbies have a narrow max wl beam with large overhangs midships
