Momac
I prefer the water to be as recently added to the tank as possible................just trying to work out the reasoning behind this?
ok i think the trick is to keep using the boat!Not necessarily true. When you're going to not use a water tank for a long period not only should you empty it, but you should dry it out. There are a couple of methods to do this. Then it's a case of a quick wash when you want to use it next. Leaving the water in the tank in a potentially warm, wet environment bacteria thrive and it can be a touch more challenging to clean depending on how the bacteria has spread. Even if you've reduced the water content by 98% you've reduced the area that bacteria can use.
And it means that you won't be tempted to drink it...
Makes sense.I prefer the water to be as recently added to the tank as possible.
For ordinary cleaning Milton is the approved stuff. Soak tank and feed pipes for an hour with required dilution and flush through for bio security. However, look at the tank feed pipe and other places where crud can accumulate - a bit of bottle brushing with Milton may be advisable.Finally getting around to cleaning (if needed) the water tank and pipes on a new to me boat I recently bought. I've no reliable idea when it was last done and don't know what current water quality is like. There are some well old Aquaclear or such like tablets on board. Thinking of buying a water quality test kit to start with. Metal water tank, plastic pipes. Please, any advice out there? Would very much appreciate advice available. Thanks.
"Approved" by which recognised authorities? Milton is essentially very expensive, very dilute bleach in a fancy bottle. For cleaning, ordinary household bleach does exactly the same job for pennies. It's perfectly safe for cleaning water tanks.
Yes approved in the sense it's good for gear used to feed babies, so right for me. Anyone wishing to up the dose, for no good biological reason, is welcome to their opinion of course....there is private label Milton if pennies are the determining factor...
Oh, and do consult on the effects of chlorine......especially in higher concentrations.
Risk of frost.What is the reason behind leaving them empty? They will always be damp internally.
Thanks very much. So about 500ml thin bleach in total should do the trick. First task will be to find somewhere in Burriana that sells it! ?
Risk of frost.
