Brick cleaner is fine for a propeller. Just wonder why you have Coppercoat on or near your propeller. The cleaner works best if you take the prop off and put it in a bocket of dilute cleaner overnight. If the prop is still on the boat and is bronze then mechanical means are probably better.
I use acid to clean the hard to get to bits on our folder. The blades themselves get sanded with a fine flap wheel on the grinder. Takes a few mins.
A bit of wet n dry finishes off any bits missed
