CLEANING OUT A DIESEL FUEL TANK ?
mica
2 Jun 2001
Kent and Solent U.K.
Has anyone any bright ideas on cleaning out a diesel fuel tank?
? Best way to pump or syphon out the existing fuel and any tips for cleaning out the sludge.
Look forward to any helpful advice.
Regards,
MICA
I pumped out my fibreglass tank using a small (on offer at a local store for £1.99) centrifugal pump mounted on a drill and then removed the tank to the garage.
For fibreglass (and S/S) commercial steam cleaning is an option but on the basis that it was too expensive I used a high pressure wash with detergent solution followed by a high pressure wash with fresh water - followed by a week in a heated garage to let it drain completely and dry out.
Looks as good as new inside and out.
Best regards :eek:)
Ian D
david_bagshaw
5 Jun 2001
uk
Pump or syphon out slowly so as not to stir the sludge
assuming access scrape up sludge & tin it
wash with steam if poss or we have used hot water & washing powder with sucess
rinse & fill tank with bleach & water
treat fuel with bio agent while out & change all engine filters, return fuel via a fine filter, personally removed engine filter for the purpose last time.
David
www.yachtman.co.uk
