Cleaning Nav Light Lens
bobgarrett
10 Oct 2005
Oxfordshire
The steaming light on my boat is no longer clear - its an AquaSignal type 41. I was going to replace the clear lens part but then wondered whether it can be cleaned up or polished - or whether like perspex hatches the damage is not just on the surface. Has anyone successfully cleaned such plastic lenses before and how?
jac
10 Sep 2001
Home Berkshire, Boat Hamble
Previous boat had Aquasignal stern light that was on it's way out. I tried several things and whilst i got it cleaner it was never satisfactory. I just ended up buying the same model from the local swindlery and only using the lens and it's housing ( basically the bit you remove to change the bulb!)
Refueler
13 Sep 2008
Far away from hooray henrys
You would be amazed what you can do with a clear plastic Coke bottle ......
I have temp replaced a steaming light 'glass' from a cut out of Coke bottle plastic.
My anchor light on top of mast - had an 'antique' bronze framed real glass .. which got broken one year. No chance to get another real glass ... so a 300ml clear coke bottle cut and fitted .... been there years and still shines out like a shaft of .... (Oscar Wilde ??).
RunAgroundHard
20 Aug 2022
They can be polished up if lightly faded. A polishing soap, or Solvol Autosol on a drill mop will work. A lot of effort for minimum effect. Replace if deeply scraped. However, it does work to a degree.
My experience is from polishing plastic windows on shot blasting cabinets. Eventually the window would dull up with shot blasting drift and this would polish out on a mop with fine polish soap.
alan_d
15 Mar 2002
Scotland
I discovered that I could buy a replacement lens for my badly crazed stern light. Then I discovered that I could buy an identical replacement stern light more cheaply than just the lens.
Stemar
12 Sep 2001
The lights on Jazzcat were crazed and grotty. They got replaced with cheap and cheerful LED lights. OK, I'll have to throw the whole thing away when the LEDs fail, but they're bright and seem to have the right cutoffs. Being LEDs, of course, they use a fraction of the power of the old bulbs. I'd take the opportunity to modernise.
Refueler
13 Sep 2008
I fitted a motorcycle LED driving lamp ... about 3" diameter as a 'spotlight' on front of my Soviet Speedboat - to light up my channel entrance when returning at night. WOW ... for very little power - I have a light that puts out enough to highlight entrance from far off !!
The dual Port / Stbd light is LED as well ... and that is also BRIGHT !!
Spotlight :
4LED Motorcycle Headlight Spot Light DRL Driving Fog Lamp Waterproof 12-85HF BII | eBay
Nav Light :
12V Marine Boat Yacht Pontoon Port Side Starboard LED Navigation Light Red/Green | eBay
I am in process of changing ALL lights to LED ... cabin / cockpit / nav ... all ..
Sandy
31 Aug 2011
On the Celtic Fringe
duckduckgo.com
I hear toothpaste will sort out a car headlamp cover. Might be worth a go and see if it works.
Refueler
13 Sep 2008
It has been a few decades since I used a CD. Oddly, my daughter has a vinyl collection! All those horrid scratches crackles and hisses.
I tried to resurrect my record players ..... but years of neglect took their toll. Then Lidl had a sale of a very good turntable with adjustable speed control ....
Yes - the records are not so 'clean' sound as CD's and MP3 ..... but its fast coming back into fashion.
My Son is lead guitar of a band ... they were recently advised to cut records as well as CD's .....
