cleaning my sail
dilly
24 Dec 2010
cardiff
Hi guys thinking of cleaning my sails in situ on the mast any idea of good solutions or chemicals or methods or things to use. i was thinking of soapy water jet wash and scrubbing brush, any ideas will help thanks David
On the mast ???????
If you insist
Lay sail and mast on a clean slightly sloping floor,
Wash with a mild detergent and water, applied with a watering can, using a softish broom. Rinse gently with water from a hose. Do not jet wash.
Hang in an airy place to dry.
I am sure it would be easier without the mast!
On the mast ???????
If you insist
DO NOT JET WASH! Don't ask.......
Hi there, I've made big improvements to general state of mainsail cleanliness / saltiness by waiting for a gentle head to wind situation in marina and wash sail as you hoist it starting with head. Use a soft brush on a pole dipping in a bucket of mild soapy warm water. Rinse as you go with gentle flow from hose pipe. Leave when hoisted to dry . Voila.
I took mine off and had it laundered by a local sailmaker. Seemed much easier option than trying to do it myself. Took it off, dropped it off at the sailmaker, picked it up a few weeks later. Clean and nicely folded!
