Jabs
I need to clear an aluminium water tank. It has no access port and the water is causing some issues.
There is a mechanical gauge which gives access to a maybe 50mm hole.
The tank holds about 600 litres.
Access is not great.
The current suggestion is to use a pressure washer and pump the water out using a separate pump rather than through the plumbing.
Once the majority of the 'grot' is out, it probably needs disinfecting to kill bacteria and delay future growth, together with flushing out the pipework
I would usually use a strong solution of bleach and absolutely slosh it all over the inside of the tank.
I assume it would be unwise to use strong bleach in ally tanks?
Would antibacterial surface cleaner do the job?
Any bright ideas for carrying out the job?
Any advice greatly received.
Thanks.
Tony
Thanks.
Tony
