Trundlebug
I had a similar problem to the OP, in that I couldn't get good enough access to make a hatch.
But I did have enough room to drill a 10mm hole in the top of the tank, in the middle either side of the central vertical baffle.
This enabled me to poke a length of copper pipe (fuel pipe, but central heating microbore will do equally well) down the the bottom of the tank and reach into all the corners.
See my post here http://www.ybw.com/forums/showthread.php?314108-Fuel-Polishing&highlight=fuel+polishing
A couple of points to make regarding some of the replies above.
It isn't sufficient to just filter out the solid black bits and think the fuel is polished; it isn't.
So using a standard CAV type filter isn't sufficient.
You need to use a filter like a Fleetguard that also absorbs water, including dissolved water from the fuel.
This is what actually prevents the bug from returning, as it has nowhere to live.
Decanting fuel, allowing it to settle and returning to tank will not remove the dissolved water which is the root cause of the problem.
Do it properly. Buy a small electric fuel pump, a filter head and a suitable filter (Racor if you must, but Fleetguard is better and also cheaper) and polish the fuel yourself. The right kind of filter will remove up to 95-99% of moisture content. A standard CAV won't, neither will leaving it to settle in a moisture laden fuel can.
It will cost less than getting someone out to do it for you, and you can then do it any time in the future at no extra cost than the replacement filters.
Cleaning the inside of the tank is a nice to have but not as essential as some would have you believe.
I wasn't able to do it and haven't found it necessary.
As there's nowhere for the bug to live, I don't have any bug; I haven't changed my primary fuel filter for over 2 seasons use now, that's around 200 hours.
