Tranona
These look interesting http://www.calcuttboats.com/engines.html
Yes, BMC 1.5 and 1.8 engines were widely used on canal boats before the modern Japanese engines came along so an obvious source for parts and service.
Indeed I would but whilst that might be a lower cost option, is it the most sensible - I wont be around in 25 years but I'd be happy if I can sail for another 10!
you can lead a horse to water but..... Finished with this thread, total bowlocks
Calcutts are the specialists on this particular engine. The OP says they are the nearest to him. No brainer really.Before you jump in I would suggest you contact:
Southern Cylinder Grinding Co
57 Nithsdale Drive
Glasgow
G41 2PT
Telephone: 0141-423 2246
They have ground, bored, sleeved, balanced, straightened rods etc for HWMO's numerous engine rebuilds. Seems sleeving is quite a common practice and often allows the reuse old pistons with new rings saving the cost of oversize pistons
On this 'rebuild, recondition' subject and bearing in mind a recent agonising thread about legal definitions Is there a 'standard description' of what would be done to 'recondition' an engine.
I have seen some attempts by companies doing this kind of work though some have vague statements such as 'examine for wear' rather than 'measure against manufacturers tolerances'.
It would be good to have a guide in order to know just what should have been done and in case there are issues under any warranty they may offer.
...However, "exchange" units which incorporated reclaimed parts were a major part of the spares and service business of most motor and ancilliary manufacturers - think Lucas electrical...
Sounds like you were referring to 'Gold Seal'?
Quote
"The engine is 25 years old and I've had it winterised and serviced each year (20 years).
It has always started well, runs smoothly and has never let us down. There has been an oil leak and we've been using around 1ltr of fresh water each day - that was a leak which was subsequently traced in October."
Given that would you be happy with the same model of engine but rebuilt and good for another 25 years?
How old are you? 25 years would take some of us to 90 or beyond!
Yes, all major manufacturers had exchange schemes as there was huge demand for replacements. Typically engines would only last 40-50000 miles (2000 hours) compared with today's expectations that small diesels such as used in boats go at least 8000 hours. Automotive engines today also have similar life expectancy, that is 3 or 4 times old 1940s designs like yours and outlast the rest of the vehicle.
The A and B series BMC engines and the 85 bore Ford engines (Anglia, Cortina etc) were the staple of reconditioners. Large volume, short life, high commonality of components and ready availability of wearing components (pistons, rings, bearings) and simple construction all helped.
So despite all the hype about "old" being "good" you have a legacy of a bygone age and have done well to get 25 year's use out of the basic engine. Just unfortunate you are the one stuck with the dilemma of what to do as it has reached the end of its useful life.
