prv
I know I'm almost certainly going to regret asking this question, but some kind of morbid fascination drives me to ask anyway
. And just maybe, someone might have some factual information rather than gut feeling...
So, here goes: is it a really daft idea to cut about three inches off the end of the shank on a bog-standard knockoff Danforth, used as a kedge on a 34 foot boat?
I ask because I really have nowhere else to put it except in the dedicated kedge locker built into the stern, and the 10kg Danforth I've just bought will not quite fit. The boat crams a full-width aft cabin into 34 feet, and the casualty is cockpit locker space, hence lack of alternative stowage. I don't want to switch to a smaller anchor as I don't reckon the fluke area would be sufficient.
I wouldn't dream of messing about with a carefully-engineered new-generation anchor, but this is a relatively crudely (though strongly) made copy of a generic design, and I suspect the dimensions are not all that critical. In any case, I can't really see that the length of the shank makes much difference to the operation of the anchor, since the pull of the chain (I have 10m of 8mm chain) is always in line with the shank when the anchor is in use. The shackle will still be well outside (about 4" outside) the tips of the flukes, and holding the anchor at both the old and new positions it doesn't seem to appreciably change the angle of dangle (shank hangs straight down in both cases due to the weight of stock and crown). I guess there's slightly less leverage to pull the flukes out when lifting the anchor, but I'm willing to live with that.
I have some zinc-rich paint which claims to be almost as good as galvanising, which I'll apply to the cut edges. The thing's rarely going to be put in the water anyway.
Fire away...
Fire away...
