Choosing a radar
Piers
2 Jun 2001
Guernsey, Channel Islands
www.playdeau.com
Try calling Dave Wellcome of Raytheon. He's an engineer and a mine of information, having helped many people from this forum. 02392 693 611 extension 1614
<hr width=100% size=1>Piers du Pré
http://www.dupre.co.uk
beneteau_305_553
1 Apr 2002
Norfolk UK
I got the Furuno 1622 from cactus navigation.
It's, in my view, excellent.
It has a 2.2 kW transmitter and I especially like the guardwatch alarm and watchman low power features. Also the resolution and clarity of the display is good.
<hr width=100% size=1>Richard
andyorr
30 May 2001
UK Glos
Did you fit this yourself? If so, was a straightforward job? If not how much did the labour cost? Oh, and how much was the unit?
My wife is very keen to have one! (But, so am I if I'm honest - so many scary fog stories from the Raz de Seine!)
Talbot
23 Aug 2003
Brighton, UK
if money is a serious concern then the JRC 1000 is a good no frills purchase. It also has the smallest/lightest scanner. The downside is that bearing accuracy is less than one with a larger scanner. The new Raytheon 2kw seems to be a nice tool. If you travel to the states at all, then the purchase of a JRC 1000 really becomes a major saving (abt £500 at the moment).
I also installed the Furuno 1622 and after a season I can report that it is an excellent product. The packaging and manual are superb and installation which I did myself is easy. I had a small query about the cabling which I had to cut and reconnect below deck (some of it screened) and the technical assistance from Furuno Aberdeen was very good and to the point. I used a Scanstrut radar bracket.
Apart from radar I also use the display as a depth sounder and GPS cockpit repeater(it can take two NMEA imputs despite what the salesman said: again technical support was very helpful with this)
I think that if you install yourself the warranty is reduced from 2 years to one year but a professional installation would have cost an additional 400 pounds. Some dealers are willing to offer a commissioning service which is cheaper.
Chris_Robb
15 Jun 2001
Haslemere/ Leros
I went for the Ratheon -now RayMarine - SL72. Much better display than the JRC, and I thought the extra was worth it. That was 3 years ago.
Dead easy to fit - especially if you are not mast mounting, using a predestal on the stern.
I would also say, don't worry about mounting the radar high, in order to get the range. In reality it is the 6 mile range and below you will use in real anger.
Best thing I have every fitted - and used in anger many times,
Chris
beneteau_305_553
1 Apr 2002
Norfolk UK
I mounted mine on a 2 " dia post at the stern.
Installing the post took the longest time. Installing the set was very simple:
- connect the cable to the radome. (terminal strip - approx 8 wires.)
- Take the cable to the display and plug it in.
- connect 12 v supply to the display and turn it on.
I mounted my display unit at the nav table but left the cable long so I can take the display into the cockpit if required.
I think I would mast mount the radome it if I did it again . The radome is so light. Furuno can supply the mast brackets.
I am thinking of connecting it to the gps nema so you get a position of waypoints shown as lollypops on the screen. plus all the nav data. etc. but I am also thinking of connecting the autohelm (st1000) and a laptop and gps or a chart plotter to the nema aswell ! any advice?
