srah1953
Further to some interesting discussions fuel filters, I would be intersted in finding out how a vacuum gauge is plumbed (if that's the right word) and any recommendations for choice of gauge.
The vacuum gauge is connected to the inlet side of the filter housing but it doesn't matter if its connected to the outlet either. The pump has to work harder as the filter blocks and this is measured by the vacuum gauge anywhere in the system, upstream of the injection pump.
Errr, no. The inlet side of the filter housing is certainly not the place to connect it - the gauge won't show anything of value. It has to be plumbed in between the filter outlet and the engine lift pump; in that way it will show the progressively increased vacuum as the filter gets blocked.
If the filters were down stream of the injection pumps then what you say would be true. The inlet side is an indirect measure of filter blocking for this type of system.
The fuel injection pump draws down a certain pressure to overcome the parasitic losses in the pipe work from the tank to the injection pump inlet. As the filter blocks the parasitic losses increase.
The injection pump is delivering the same quantity of fuel as its a positive displacement pump. The fuel velocity down stream of the blocked filter must increase to keep up with the demands of the pump. As the injection pump is providing the power to pull the fuel through (not the lift pump pushing the fuel) then a pressure drop is realised all along the pipe work from tank to injection pump. Hence, the vacuum gauge does not need to be plumbed in to the outlet on these types of systems.
.....To make further analysis of increasing vacuum pressure I agree that you need the gauge mounted on the outlet of the filter unit.
So what's the lift pump for, then?
At last! We got there in the end.
Yes but if you only know that the vacuum gauge is on the outlet from the fuel filter you are in exactly the same position as if its on the inlet of the fuel filter. That is my point.
There is no point having a vacuum gauge on the inlet of a filter - it won't give any warning of the filter becoming blocked (most likely scenario), although it would warn of the pipe from the tank becoming blocked (highly unlikely scenario).
You are wrong, it will tell you that there is more suction happening on the fuel pipe system which may be due to the filter blocking. The mechanism that it does this has been explained by me as best as I can.
If you mount the vacuum gauge on the outlet of the filter it will still tell you that there is more suction happening on the fuel pipe system which may be due to the filter blocking.
In both mounting positions a restriction at the tank outlet or a blocked filter will show an increase in suction pressure. With no other information all you can do is change filters and see what happened to the vacuum gauge.
Here is a picture of a filter system where the vacuum gauge is on the inlet manifold: -
