aluijten
Use the correct instrument for the job - a differential pressure indicator across the filter.
Just as I said at the beginning of this thread
Thank you.
So what's the lift pump for, then?
Err... Gents, as far as I can see this thread originates from the premise that we are talking about fuel filters - the link to the vacuum gauge refers to a fitting for the air filter and bolts onto the top cover of the filter - thus measuring the air pressure AFTER the air filter.
A vacuum gauge makes more sense in this context where is IS measuring differential pressure across the air filter, but none as a fuel filter gauge.
I have.Perhaps you should read the whole thread? Especially post #19, then maybe look at the Vetus catalogue pages on fuel filters.
And perhaps you should read post #4, from where the thread originates where a link is given to "Instalation instructions for a ParkerRacor vacuum gauge" which refers to an air filter gauge.
If you view this resulting thread hanging off this post it appears to be based largely on the argument that a vacuum gauge at the inlet of a fuel filter will tell you something about the filter condition whereas the equipment cited was a vacuum gauge for an air filter.
If it helps any, the latest crop of Euro5 diesel cars, fitted with particulate filters, have a pressure tapping before and after the particulate filter. The pressure immediately before and immediately after the filter is monitored and the two are compared so that the engine management system knows when the filter is getting blocked and needs a regeneration. Obviously, this is all positive pressure stuff, but clearly, the only way the car manufacturers feel this can work is by monitoring the pressure drop across the filter, with two transducers.
just assume the fuel flow is about 1 GPM. It is usually a touch less, but using 1 GPM or 60 GPH is a good number to use when calculating fuel system design.
All good stuff I'm sure, but my engine consumes about 1.5 litres per hour on average...
The fuel consumption is not relevant, it is the flow rate through the filters that matters. Remember that most of the fuel gets pumped back into the tank.
Most? The injector return nozzles and return lines are 2 mm bore, maybe 3 mm, from memory. My filter is rated at 50 litres/hour, which I'm sure is vastly over-sized.
This thread's still going? Are people that bored at christmas they need to argue about vacuum gauges on teh internetz?![]()
I reckon you've had too much Christmas cheer already! The Parker Racor link is to a vacuum gauge for a fuel filter, not an air filter. Look at it again!
Merry Christmas.
I'm quite familiar with DP gauges used on pressurised systems such as lub oil filters, where a differential of around 1 bar might be expected. Are DP gauges available for the very low pressure ranges that might be encountered in fuel filters? With a keel tank the pressure at the filter inlet might be well under 1 bara, with a fouled filter pressure not much more than 0.2 bara.
Further to some interesting discussions fuel filters, I would be intersted in finding out how a vacuum gauge is plumbed (if that's the right word) and any recommendations for choice of gauge.
Contrary to some nonsensical stuff posted in this thread the vacuum gauge would be plumbed on the outlet side of the filter to show the progress of a plugging filter. This is provided the lift pump is sucking and not pushing through the primary filter. If it is pushing through the filter you would not use a vacuum gauge to monitor filter restrictions.
I have had to re-plumb two vacuum gauges incorrectly installed by DIY's that were installed on the inlet side of the filter. In one case the engine died due to a plugged filter and the vacuum gauge never moved off the pin. Flipped it to the outlet side, before changing the filter, and it was showing a massively plugged filter and then the engine would sputter and die.. On the second one the same result. No reading at all on the inlet and a reading of plugged on the outlet side. In both cases these were Racor turbine filters where the owners were too cheap to buy the t-handle vacuum gauge adapter fitting so they used a brass tee..
I use a fluid damped drag needle gauge from Sailor's Solutions in the US along with the t-handle vacuum gauge adapter. The nice thing is you don't have to monitor it while under load to get a reading. I can watch the progress of our filter beginning to clog and change it before it becomes a problem...
