skyflyer
Here is a useful FAQ distillation someone on that site produced
Id recommend a look. She good videos there and lots of 'real world' experience including who are the good and bad suppliers
ok ill also answer 20 questions that people have asked over and over maybe it can be pinned to the top.
1 do they modulate up and down, yes they do,all heaters have a thermostat inside the heater that monitor the air temp and compares it to what is required on the your controller and will adjust to that setting.
2 do they have a 7day timer yes if you buy the one with the lcd display with round buttons.
3 do they show faults, yes they do either by way of fault code on lcd display or flashing lights on knob type.
4 can they be fitted sideways or external yes to both sideways you must have it glow plug up to work.
question.
5 how to connect in, you plumb the two bottom pipes and fuel to outside elements and connect the two blower inlet/outlets inside. 6 can spares part be obtained yes they are all available from china .
7 are they all from china on ebay ,yes just different sellers names, tho some people are buying them in bulk and selling them in uk with a added cost on this site.
8 will they burn your van down, err no no fire as of yet to my knowledge tho nice warm vans.
9 are they approved, a grey area this,there is a cert that conforms they have been tested for military use in some capacity for cezch military on here floating around. Copy of cert below.
10 are these genuine planar, no these are chinese copies of eberspacher, the genuine planer is similar to webastos and made in russian.
11. shipping times,it varies from seller to seller from a week to 8 weeks tho most of this is down to customs i feel and postage carrier.
12 do you have to pay import fees, some have had to pay i believe from dhl carrier about £30 extra, but most on the whole have got through with no extra charges.
13 do they come with a warranty, yes 12mths from the seller but how good this is,is yet to be confirmed tho most issues seems to be handled ok from sellers thus far..
14 how new are these to market, these heater have been sold in the usa for the last 10 years and can be brought of the shelf in many stores, they are more new to the ebay uk market.
15 whats the quality like, ok the main unit is very good,the jubilee clips weak and you may need longer hosing for ducting and exhaust runs as you only get 0.5mtrs of each, but they are only £150 and well worth the money thus far given the alternative prices of others.
16 parts missing, ok so some kits have came without the exhuast silencer, mine came with the floor plate missing but had a silencer, but on the whole all the major parts are there, either they packing is a little poor or they may be low on stock for the kits. but still for the money they are a worthwhile investment even with the odd minor part missing, missing parts can be brought from ebay from eberspacher dealers if need be.
17 fuel types, they can be run on road diesel or parrafin, red diesel and kerosene, they use 0.2ltr per hour on low and 0.6 ltr on high,tho mostly will be run low once modulated down.petrol version heaters are available.
18 tips run the heater on max for ten minutes before you turn them of helps to burn any carbon off, parrafin is useful for decoking them as it burns differently and cleaner to diesel as its the only fuel rated for indoor diesel heaters too.
19 can they be connected to vehicle fuel tanks, yes as long as its a diesel vehicle and you know what your doing otherwise use the free tank in the kit.
20 using them while travelling, yes you can use the heater while the vehicle or boat is moving tho make sure you fuel tanks are topped up so you dont suck any air into pipe lines.
21instructions yes they normally come with english instructions showing how heater is to be connected together as for fitting into vehicle you have to adapt the info across
22 remote control option.there are remotes and gsm mobile controller in the chinese aftermarket stores that may well be compatable.ive yet to test one of these
23 extending pipe work, yes you can, the exhaust is 24mm and can buy it per mtr of ebay also ducting etc of ebay
24 power, they come in 12v or 24v, 12v ones pull about 20 amps on start up for glow plug then drop down to under 2 amps
