JumbleDuck
All the same, I'd hate to have to explai to the Coroner why one was out of date!
With a bit of luck you wouldn't have to ... without a working LJ the body is unlikely to be recovered.
If I fall off the tender I'm probably only going to be in the water a couple of minutes.I'd imagine far more people fall off boats in the course of boarding/berthing manoeuvres than go overboard offshore. All my lifejackets are approximately the same age and quality. However, if I had a variety, I'd use my most trusted equipment where I'm most likely to fall overboard rather than keeping it 'for best'.
My plan is to keep shiny new ones for offshore use and downgrade them to RIB/tender/local racing after a couple of years.
They still have to work of course!
I'm not on the water every day, but the wear and tear is still significant. More so since we've taken to wearing them in the tender more.
To be clear, you're saying the empty cylinder has probably been there since 2009, so in eight years you haven't done the normal annual checks even once?
Well done for admitting it, I guess, since it might nudge others into checking theirs. But I find it pretty alarming.
I think in future I'm going to avoid ever borrowing lifejackets from leisure sailors.
How many times have you or someone else worn that jacket assuming it would keep you afloat if you fell in?
I have a similar annual regime to most on here.
One issue I have a question on: I have two cylinders where the body is quite corroded - surface corrosion only - the bottles are quite thick, of course. However the thread and cylinder cap cover are in good condition (nice & shiny), and they weigh just fine.
Are these bottles to be considered bad? And if so .. why? The only thing I can think of is that they are now rough and might abrade the innards of the jacket?
Someday soon someone is going to invent the locking nut then they won't accidentally come unscrewed all the time.
Crewsaver. You get at the cylinder by dismantling the hammar trigger mechanism - something I'll need to learn how to do this winter, as the mechanisms are about to go out-of-date.
The replacement Hammar sets come with a little metal key that hooks into one corner of the unit and, when twisted, turns the black locking ring by ten degrees or so. This separates the outer and inner halves of the mechanism from each other and the whole inner part together with the cylinder then comes out through the hole in the bladder. You can check the state of the cylinder (should be fine sealed inside the dry bladder, which is why they do it that way) and re-use it, but if you decide to replace then you need a specific cylinder with the inner part of the mechanism already glued onto it.
Do the inflation test after reassembling the Hammar, not before, because it can occasionally go together correctly but fail to fully seal on the bladder ring, resulting in a slow leak. Dismantling, reassembly, and re-testing should sort it.
Personally I'm content with the Hammar-operated jackets I have, but I don't think I'd choose them again. It's not clear to me that there are any benefits in exchange for the various slightly fiddly aspects of servicing, and the parts are more expensive.
Thanks you. Much obliged.
I tend to agree, although I do like the idea of the mechanism living snugly inside the bladder.
