lustyd
Having got my prop off (thanks again WRR!) and the cutless out we found the engine out of alignment by enough to make the end of the shaft feel heavy when pushed up. Upon further investigation I found the nut on one of the rear mounts missing entirely, and the lower nut had presumably vibrated itself down to the bottom of the thread. This meant one corner of the engine was about an inch too low.
We did a very big trip last year so lots of miles and plenty of hours on the engine. Not once did it occur to me to check my nuts, hence this thread telling you to check yours regularly. They should be tight, so any movement at all in the top nut suggests a problem that needs fixing. The fix is simple, just adjust the nuts and align the engine again. Adjusting a nut 1/8th of a turn at a time and having to flip the massive spanner every time due to limited space, hoses, wiring, etc. is exceedingly frustrating work, especially when it needs 10-20 full turns!
When did you last check yours?
