george unthank
I have a Regal 2565 D3 diesel engine - year 2006/7 180 hours on clock
I' m getting a '' CHECK ENGINE'' signal from my EVC immediately after the ignition has been switched on and has run through its paces of its own computer system. I have checked all fluids from engine oil to coolant - 5 fluids in all- 6 including fuel - ; they are all within normal range . I crank the engine and she starts without a problem . No white or black smoke noted . No odd smells.
This started earlier this week on her first trip of the season . I took her up to the recommended temp before revving up to her max speed ; 27 mph.
I get to 18 mph (about ) and she drops speed and revs immediately . when this happened initially I cut engine , dropped anchor and checked fluids again . When I went to start her on battery 1 ( there is a port and starboard engine - it is recommended you start engine at ''ALL'' position then switch to 1 or 2 for charging purposes .)
Battery1 was practically dead , she started with 2 bats - ALL position , and I made my way back 3 miles to my club at 5 mph . and replaced bad battery .
Since then she displays this engine alarm ''CHECK ENGINE'' - despite getting new battery and running get a short distance a few times.
I have put this problem to the forum here without the more recent observations , so may I thank auk who kindly did reply and offer their v sound advice.
I am re- articulating the problem from a slightly different perspective . Your contributions have been very insightful
You will find my previous post under George unthank
Do I simply have to get a Volvo Penta mechanic with a diagnostic computer kit .?
Or is there anything I can check before ''importing '' a Volvo mechanic in as there are none in my area , and the other mechanics do not have the \Volvo software .
If it is a question if getting a Volvo mechanic -so be it
Any advice appreciated
George
George
