Otter
Is there any alternative to the budget busting Rutland charge controller for an Aerogen4? It's going into a 420Ah bank and will only be 'on' when we're on board.
Thanks.
Thanks.
Something like this?
Saving around a hundred quid....but a bit 'clunky'
http://www.ebay.co.uk/itm/12V-600W-...21129452116?pt=UK_Gadgets&hash=item4ac4ce9254
This unit might be a little better as costs about £15 and is just a regulator/controller:
http://cgi.ebay.co.uk/ws/eBayISAPI....akeTrack=true&ssPageName=VIP:watchlink:top:en
As the Aerogen is basically an alternator, could you not use/modify a standard regulator from the motor trade?
All it would have to do is to limit the output by controlling the field windings of the Aerogen when your batteries are fully charged.
. . . . . I think that I'm right in saying that both the Aerogen and the Aquair, in common with many wind generators, do not have the ability to have their output regulated in the same way as an engine alternator (ie vary the current to the rotor coils so as to control the output voltage) as they do not have rotor coils: the rotor is a set of permanent magnets and the output comes from stator coils. A wind turbine regulator senses the battery voltage v the output voltage and if the battery voltage gets too high it dumps the excess energy to a dummy load. Thus the first ebay regulator will provide the required protection to the batteries by dumping to the dummy load whilst the solar regulators will not achive anything.
In that case, as the OP only wanted a regulator the load should still be on the yacht and he possibly only needs:
http://www.ebay.co.uk/itm/12V-600W-...21127216995?pt=UK_Gadgets&hash=item4ac4ac7763
this is the same unit that VicS suggested without the (clunky) load thereby saving about £30?.
What you will find in fact is that modern regulators such as the Rutland HRSi do not dump the excess power. They are PWM regulators. http://www.marlec.co.uk/products/windchargers/windcharger-controllers/hrsi-charge-regulator/
They also reduce the speed of the turbine, as the battery charges thereby reducing wear on the bearings
However he OP's Aerogen may not be suitable for use with this type of controller. The Aerogen regulator is in fact a dump type and a retail price of £164 a lot more expensive than the Rultland HRSi which is only £75
I have also just bought an Aquair 100, and I have bought the unit I am proposing, which will hook into my Sterling Alternator to Battery Charger.
Bit of Fred Drift...
The Aquair 100 manual suggests using the Ampair regulators (funny that), which seem to simply disconnect the generator once the batteries are charged. Much like in towed mode where it says to disconnect the wiring once the batteries are charged.
Rather different way of doing things.
LK,
here is a link to the LVM manual for the Aerogen. It has electrical brake wiring information there, and an output graph which suggests it can be that powerful....
http://www.shop.solar-wind.co.uk/acatalog/Wind_turbine_LVM_AERO4GEN_Marine_Manual.pdf
Simplicity is a virtue, however, my memory is poxy, so something that will switch it off for me seems to be a good way of heating the cabin that the dump unit is in.
