vas
hello,
got this:
https://www.ebay.co.uk/itm/1-1000A-...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
for less than four quid.
Didn't realise how small it was...
I'll feed it with starter engines 24V output in order to charge a 90Ah flooded led acid generator battery.
Prior to that I didn't use a dedicated gen battery and was nicking 12V out of the 2X12V engine start batteries and managed to destroy both, so lesson learnt (almost) and got three new batteries.
Alternatively I could buy a 220V->10-30adj output dropper and hook it up there so it only works when the generator is on, but since generator may be off duty for months, I'd rather have some sort of freshening up...
I'm thinking of not having it on permanently and only run it a couple of days a week with a timer or something.
Before someone asks, yes, yanmar 2GM on my Mase 8KW generator didn't have an alternator but was using the generator second coil or something like that to provide 12V. Problem is that this output is dead now and not planning on taking the generator apart to fix it, nor paying 50+ to get an alternator for it.
anyone tried something like that?
Generator battery is used only for starting up (so consumes whatever the starter needs) and then does nothing till next start (even oil/temp sensors are fed from the NMEA2K supply)
cheers
V.
got this:
cheers
V.
