eddystone
I planned to get a cheap (about £12-15) PWM charge controller from ebay to control 2 x 20W solar panels going into 3 x 85 ah batteries. Is there anything wrong with these - are the £30 worth getting instead?
As always, it depends how much power you use, only you can decide that. But I would think 2 x 20w panels would be fine assuming you're not running air-conditioning 24/7. 40 watts divided by 12 volts gives you 3.3a so a 5 amp controller would be OK. Generally it's not necessary to charge the engine battery with solar, the alternator will replenish the power used in starting in a few minutes. So only connect the solar to the leisure batteries but maybe have some means of starting via the leisure batteries if the engine battery develops a fault. A bypass switch is ideal but you can use jump leads (but not so convenient).OK I have 1 x 85 ah engine battery and 2 x 85 ah service batteries in series (I think) making 1 x 170 ah service battery. As PWM dual battery controllers are expensive and this is a low cost installation to keep the house batteries topped up, seems I have 2 options. 1) Run the wiring for the 2 panels separately through a controller each to the engine and service batteries. however, I also have a jump starter for emergencies if the engine battery won't turn the engine so ...2) Connect the 2 panels in series and then into single regulator into service bank. Presumably if they are connected in series (if that's the one where Ahs are summed but voltage stays the same) its OK to connect to one of the batteries (I'm not doing it myself just supplying the kit)
I assume with 2 x 20 watt panels a 5 or 6 amp controller will be sufficient?
I recently bought two 100w panels and two PWM chargers - not yet fitted.
My logic is that the two panels may have widely different conditions ie one in sun, the other in shade or shadow. A single controller will set itself for the higher output panel and effectively ignore the other. But with two controllers they'll each be operating according to the panel they're connected to and there'll be useful power from both.
