Cheap portable generators
PhilS
15 Mar 2012
Woodbridge, Sail from River Orwell on East Coast
CLB
18 Jun 2013
I have a Kipor, basically a copy of a Honda. Bought it about 10 years ago and used it last week. Never broken down, never let me down but it might be pot luck.
Concerto
16 Jul 2014
Chatham Maritime Marina
Check out the noise level emitted and you will see how quiet the more expensive generators are. Look for one near 50db for a low intrusion to life on board. 60db is quite intrusive.
philwebb
8 May 2002
london
Hi +1 for Kipor I bought a second hand one to power tools for some big jobs on my boat and have found it very good. Easy to start and reliable.
Steve_N
31 May 2004
Fife
I noticed that £200 gets you a cheap 1200W generator that has fairly good reviews on Amazon. For example the Wolf
https://www.amazon.co.uk/Wolf-Leisu..._1_2?s=outdoors&ie=UTF8&qid=1532465271&sr=1-2
I believe this is unrelated to the Wolf that makes garden machinery. A "real" Honda generator is £800.
Anyone getting good results from low cost generators? I would rather pay £200 then £800!
I think it's an Impax. Screwfix and others sell them as Impax while some including Machinemart re-badge them.
I've been using the smaller 700W just to run my 20A Sterling charger, plus the occasional other task, for a couple of years now and all good so far.
The noise level is quite acceptable.
https://www.screwfix.com/p/impax-im800i-700w-inverter-generator-230v/15760
MM5AHO
1 Oct 2007
Central Scotland
I bought a low cost one and it has proved very reliable and economical.
But it does emit radio frequency noise, enough to make ssb and VHF both un-usable while it's running.
charles_reed
29 Jun 2001
Home Shropshire 6/12; boat Greece 6/12
Anything cheap wears out quicker and will need to be replaced.
A grand simplification - more elegantly covered by the original old saw "buy cheap, buy twice"
I've heard good reports of the Kipor, except for noise levels and fuel consumption. For most leisure users the better engineered Honda scarcely justifies its extra cost.
RichardS
N/A
5 Nov 2009
Home UK Midlands / Boat Croatia
I don't think that there is any portable generator which will produce anything near 50db unless it is just ticking over, and even then I'm sceptical. Once it is actually being used meaningfully I would bet that they are all way above 60db at a typical working distance. :confused:
Richard
No Regrets
9 Jul 2007
https://www.ebay.co.uk/itm/Draper-2...774265?hash=item1cb1d77ef9:g:ftcAAOSwqWNbROgW
I bought one of these a year or two ago. Quiet, like the Honda, slightly lighter, and works very well indeed.
Now on it's second service, no issues, and a 2 year warranty from Draper. Spares are apparently available as Draper give a toolkit and spares catalogue with every new machine. A dubious philosophy perhaps, but it shows there is a decent back-up!
Very very happy with it. Had an Eu20 (a few actually!) so able to make the comparison.
prv
29 Nov 2009
Southampton
My £250 3KVa generator is still going fine after nearly ten years of intermittent use, mostly running power tools in the yard, sometimes in the rain and with essentially no maintenance. I don't think I've changed the oil more than once in that time.
It is bloody noisy though :). I used to tuck it in amongst the abandoned projects at the edge of the yard with the exhaust pointing out over the water, and run a long extension lead to where I was working.
lw395
16 May 2007
A lot of vendors are quoting dB at longer distances like 7m.
What's tolerable is going to depend whether it's for use with tools now and then or whether you're going to run it all evening to watch Tv or whatever.
I've got one of the older 2 stroke 700W generators which is OK for running power tools now and then.
Graham376
15 Apr 2018
Wolf is just a brand name now for mainly cheap Chinese imports. Have had a few cheap generators but all failed for various reasons. We've had a Honda 20i for a few years now, quiet when just battery charging and unlike the cheap brands, lots of service agents and spares around if it does break. Beware of any Screwfix own brand machinery, there's no service backup or parts for many items after warranty expires.
prv
29 Nov 2009
Southampton
Whatever it is, if it's placed in the engine compartment then it should be acceptably quiet. Running the fans while charging should also keep it cool.
This is about portable generators rather than installed ones.
It ought to be possible to DIY one into the other, but you'd have to do a better job of it than that man who killed his wife and kids when the solder in his home-made exhaust pipe melted.
