Cheap & effective riding light
JimC
30 Aug 2001
Lancashire
Here: http://www.a1leisuredirect.co.uk/12-volt-fluorescent-tube-lamp-154-p.asp
It only needs a few turns of self-amalgamating tape to make it weatherproof. It's highly visible at night and the linear light source should be less prone to being obscured by roller-genoas and masts than a point source. The tube is rated at 8 watts which should be equivalent to a filament bulb of around 25 watts or more. In fact it draws 300ma so it would take about 2.5 ampere hours out of the battery if on all night.
I'd worry about the waterproofing. I know these are 4 times the price at £20 but they are brilliant and have a twinkling effect which is better than a constant light for attracting attention
I'm not sure if it puts it in perspective or not but I have a torch which also has a fluorescent tube. I reckon it must be 6 watts because the 4 watt ones are only 6" long while the 8 watt ones are 12" but it is 8".
It draws 300mA from a 9 volt battery (2.7 watts).
Not sure about how good it will be as a riding light because the source is quite large so the luminous intensity, which is what is given in the Col-regs to achieve the required visible range will be quite small for the total power consumption or light output.
Re: Cheap & effective riding light
ebay, about £22 (and I saw it on lots of other sites), but now I do a google I can't find any as cheap as I paid, all over £30. /forums/images/graemlins/frown.gif
Mine is a Triton marine one. Superb, very bright light, very low consumption. In any situation where there is a risk of collision in the dark, e.g. anchored off harbours where fishing boats go out very early, this is the one to have. Over the years I have tried a variety of different types but none were better than this.
Can't say on the fluorescent one although I would be surprised if it was as good as the Triton one. My main objection to fluorescents is that they always cause interference on radio. Would this affect Navtex reception? I don't know, maybe someone ese does.
I made an LED one myself, three LED's in series with each of 6 resistors. Laid out similar to the one in the picture, potted in araldite.
You can get a lot of white led's for £20 odd quid. Current is about 25mA per 3 led's, varies a bit with battery level, it has to cope with max charging volts of 14.5V, down to about 11.5.
