Cheap Chinese Diesel Heaters the Return !
Both steel and aluminium corrode in salty air, alas unless it's an expensive make the description just says metal and plastic.
You want the Bio, BUT check to see if it lists recycled vegetable oil or Rapeseed, as they are lubricity killers. Perfectly OK in a tractor but not in any sort of modern diesel.
Have you seen a modern tractor!
Lest not complicate this more than needs be. Aslong as the fuel is not WVO just stick in any fuel they are made for. the eaters will coke up with the best diesel thats why they need to be used full wack for time to time if not always to help keep the unit clean.
Yep. It's a sub 100 quid (in the case of the Chinese stuff) heater.. Take the necessary precautions, stick fuel in it and give it a good flat-out blast from time to time.
