davey
Yanmar Problems
I actually prefer playing with engines instead of getting seasick, however re the Yanmar 1GM10, although many people think that they are marvellous I'm not impressed with them in the slightest. Firstly they are raw water cooled, secondly the crankshaft pulley which is made of grey cast iron (strong in compression but weak in extension) splits. It is a bum design that uses low tensile strength material on a taper fit. To ensure that it will split there is a keyway there just ready to start off the crack. If the pulley had been made of malleable white cast iron (often called semi-steel) it might have been OK but as usual these days you just can't seem to get the right staff. Ruggerini MD150 engines do exactly the same thing but on those engines there is the possibility of machining the spigot and shrinking a steel band over the crack. All the Yanmar pulleys that I've seen are the same bad design so it looks as if I'll have to turn up a new one on my 100 year old lathe (its was made to be driven by an overhead lineshaft and its calibrated in 64ths of an inch - not the easiest thing to use but its done some good jobs )
The engines of choice have to be the Kubota Super Mini Series. The Z482 model is used in the Aixam 500 micro car and these cars are often disposed of because of their poor performance. Two firms that marinised the Z482 are Beta and Nanni but there may be others. None of these stuff is cheap but as a boatyard owner once said "Do you know what BOAT stands for?" (I had to say that I didn't) "Bring out another thousand!" he said!
If one can stand the noise there are Chinese made diesels, air cooled but brand new for about £300.
Hi Springer
One more point make sure spare parts are still available any engine you buy and that the extra weight wont ruin your boats sailing ability.
I have a Yanmar 1GM10 very light and small in a 27`yacht and am very pleased with it but they not cheap
