Dockhead
Where on Earth do you get this from ? It's just utter nonsense.
Car type, bus type, huh ?
How do you imagine my puny 12v alternator charges my domestic bank, which is larger than the OPs ?
How do you imagine all of the other boats, also fitted with normal everyday 12v alternators do the same ?
Further words fail me![]()
Oh, brother.
Instead of spluttering in amazement and outrage, at being faced with facts of which you are simply unaware, you might do some reading on the subject.
MaineSail is a great source and a good place to start:
https://marinehowto.com/automotive-alternators-vs-deep-cycle-batteries/
A car-type alternator, 65 amps, can be expected to produce about 30 or maybe 40 amps more or less continuously. A 400 amp/hour lead-acid battery bank can accept 100-150 amps of current with no problem, AGM batteries much more. Such an alternator will struggle to get a decent charge on a bank that size -- see MaineSail's article.
A large frame alternator of say 160 amps, on the other hand, will produce 160 amps 24/7/365, because it's designed to do that.
My own second alternator, a 110 amp Leece Neville (@24v) will not only charge the large battery bank, it will run whatever AC gear on board through the inverter, whenever the main engine is running. Including the washer/dryer, electric cooking, whatever. Don't try that with a car alternator!
The point is that the OP has nothing to gain, by trying to add current from the puny standard alternator. Let the big one do its job and be happy that the starting system is entirely separate and not vulnerable to being run down by being connected with the house system.
