kalanka
I have recently replaced a switch panel on a Sadler 34, 1988. This went smoothly but on my first outing after the replacement I noticed that I have lost charging – first indicator being the tachometer not functioning. Engine is Volvo Penta 2003. There is no change to battery voltage when the engine is running. House battery bank is 3 x Deka DC27
To connect the battery meter on the new panel it was necessary to input a positive connection to tap voltage from each battery bank . I tried to do this by accessing the rear of the battery rotary 1/2/all/off switch but in the end took the feeds from two heavy red leads in the engine compartment. These new connections are running at 3 o clock here:
I assumed that I had disturbed a connection that was now preventing charging, especially the thin wire at the back of the alternator, but all connections seem sound and jiggling has no effect. Battery connections are clean and sound. House battery bank and starter battery currently showing 10.4/ 10.5 V
There is a Sterling battery management system fitted which I have never really understood. I recall it was necessary to install a new field connection (I think) to the alternator on installation of the Sterling to allow high output when charging. There was also a relay that had to be fired up to get the system to boot.
With engine running this is the display - the top Green is flashing
Here is what I believe to be the relay
I am baffled by the diagnosis of the problem and all too aware of my limitations in this area. I would be very grateful if anybody could give me some steer. I can do electrics but am generally baffled by electronics...
I suppose that a broken connection remains a possibility but other possibilities that occur to me include:
A coincidental failure of the alternator
The voltage tap has somehow messed up the power management system
Damage to a charging diode or the relay
Fault in the rotary battery selection switch
Any suggestions?
Any suggestions?
