ColinR
I have a Sterling Pro Digital regulator on my boat which fast charges the batteries. Its worked well for years. I have always had open lead acid batteries which can be charged up to 14.8v and the system has worked well because in normal cruising it generally takes about an hour to charge before dropping to a lower float voltage. I renewed all the batteries this year, two Trojan 130 AH deep cycle for domestic and an Exide 110 AH cranking battery. The banks are separated by a VSR. The Trojans are open lead acid, but I inadvertently got a sealed lead acid cranking battery and didn’t notice until it was a bit late to change it.
Sterling (and Exide) specify a maximum of 14.4v to charge a sealed lead acid battery. I can set the regulator to this, but it increases the charge time to about 4 hours which is way more than I want to be motoring unless there’s no wind. As I understand it, at a higher voltage there is more gassing and the acid needs topping up more frequently. I do top up the domestic bank now and again over the season, but the start battery never needs it. I assume this is because it is not doing much work and is permanently fully charged. The man in the battery shop said that the sealed battery is vented and the top can be carefully prised off to check if it needs topping up.
The boat is on a mooring and has a solar panel, so the batteries are always fully charged when I turn up.
Would it be safe to charge at 14.8v or should I reduce it to 14.4v.
Thanks!
Thanks!
