CaptainBob
My boat's charging circuit is as follows. The big "Shaft" on the left is the prop shaft driving an alternator which is used, via split diode and some switches, to charge a standalone "nav/comms" battery and/or the house battery when sailing and the prop is spinning.
Owner previous to me also added a VSR as you can see in the black additional wiring, which connects the house to the nav battery if house battery is over 13.6V and hence means the mains batts charger also charges the nav/com batt when house and eng bat are high enough.
What I'm considering doing is combining the house and nav/comms battery into one single bank. I'm going to be working on the boat on a laptop on a daily basis and I fancy having access to 400Ah of house battery rather than just 200Ah without having to add another battery.
I figure it will work if I modify the circuit to the following (remove split diode and vsr and shaft charge house sw and "supplies sw":
But to do this I'll have removed the diode between the shaft alternator and the batteries it's charging which will increase the voltage available from it but will allow a back-current to the alternator. Unsure if that's an issue or not.
Thoughts on my plan, and on the removal of that diode, much appreciated.
