Dave_Seager
My Princess 32 has a setup with splitting diodes just as shown in the diagram above. The diode packs are mounted on the output terminals of the alternators on a heatsink shaped to match the outline of the alternator.
I may be a bit simple but I dont really understand why the bank should be receiving a 30 amp charge. In my experience an alternator may start at that level to replace the starting current, and then it quickly drops back to a few amps to charge the batteries, according to their voltage relatively to the cut off voltage. The fact that diodes or VSR's are in the circuit should not affect this ...right??
If your batteries are dead or messed up no charge system will help. I'd say you have bigger problems then the VSR if one battery bank is draining the other as well as a 60Ah+ generator, that bank will explode as long a you keep feeding it 30 amps or more if it does not store it so I suggest you get in the life raft even if you have only one generator and one battery bank.
That aside it is not likely in a situation like that for the voltage to go over 13.8 (or you being able to start the engines in the first place ) as everything will be stressed to the max so the VSR still keeps the batteries separate.
Regarding the 12.8 volts, I can only say that you obviously don't understand how it will work in practice, trust me it will not keep the banks connected for very long. I know, I've used it.
VSR's have no place on a boat. As soon as the engine starts, the VSR will energise and effectively parallel the battery banks. If a single battery catastrophically fails it could suck the power out of all the batteries in both banks. If the battery the VSR is trying to charge develops a fault and won't hold a proper charge, the VSR has to carry all the current that this bank requires from the other bank. It isn't designed to carry such loads, nor is the wiring used. If, for instance, the bank that the VSR is charging has the windlass on it, as soon as you hit the windlass control the VSR or the wiring will be fried (hopefully the wiring won't catch light, but it could easily do so as there is no circuit breaker or fuse specified in the typical fitting instructions.
As a pertinent example, we had a battery fail at the beginning of a 150 nm trip at the end of last Summer. When we arrived at an overnight stop 45 nm into the journey i switched the engine off and all of the electronics went off. The electronics battery was totally flat, despite being charged for the past three hours by the alternator. Had we have been using a VSR, it's almost certain that the dead battery would have sucked the life out of the good engine battery. We hooked up to the shore power and the battery was on charge all night via the 25a mains charger. In the morning it was still flat as a pancake. As soon as the engine was started, everything worked fine and we were able to complete the trip, with the totally knackered battery, no problems at all.
I don't follow that - surely the VSR simply switches the charge from engine start battery to the domestic battery/bank once it senses the start battery's been fully charged? With two alternators wouldn't you just let each alternator charge it's start battery and then switch to the domestic bank?
I'm asking I hasten to add - not contradicting - as I'm used to rag and stick. We tend to prefer a big red switch anyway. It just seems a bizarre way to use a VSR to me. Also sounds like people are fitting under-sized ones as I've used 300A jobbies before on aircraft. I'd hope a fuse somewhere blew before I melted part of my charging circuitry by discharging a battery across a near short circuit.
If one battery in a bank fails in a particular way, where is will not retain any of the charge being applied to it, that battery will drain the good battery(s). Ask anyone who runs a Jap 4x4 with twin batteries, where one failed. Ask anyone who runs lorries, where one battery has failed. Ask anyone who has had a single battery in a bank on a boat and one has failed. Ask anyone who has a torch with more than one battery, and one h as failed etc etc etc etc.
, if you parallel all of your boat batteries by fitting a VSR and one of the domestic bank fails, it will not only drain the other domestic batteries, it will drain the engine batteries too.
If you think such a failed battery will overheat and cause other problems, think again.
This is misleading, the battery will only reach 13.8 volts if it is close to fully charged, a healthy starter battery will get there quickly but that also means that it is ok and will be able to start your engines the next time you need it, with or without a VSR.The VSR switches when it senses 13.8 volts. As the alternator will output more than this, the VSR will switch as soon as the engine starts.
Again this is misleading, wired right it will only connect the battery banks provided your starter battery is reasonably charged. It is not taking charge from the starter battery unless it does not need it. Its a way to use surplus charge capacity.If you were using VSR's with twin engines, yes, you would let each alternator charge it's own start battery (if you had separate start batteries) with VSR's on each alternator to the domestic bank. Problem is, as soon as the engines start, all three banks would be paralleled. The VSR does not switch the charge from one bank to another, it parallels the two banks to allow the domestic bank to take it's charge from the starter bank. The key point here is that with the engine running, all batteries are connected together.
The point of separate banks is indeed to minimize the risk of being stranded with flat batteries but NOT because you have them connected when you are charging them, its to keep the starter battery charged incase you accidently discharge the domestic bank using the fridge, heather, lights etc when the engines are not running or you don't have shore power.The point of separate banks for engine/s and domestics it to minimise the risk of being stranded with flat batteries. The use of VSR's is therefore inappropriate, IMO.
The exact system that would be best for any given boat will depend on several factors. For boats that aren't away from shore power for more than, maybe, 2 or 3 days at a time split charge diodes offer a cheap and reliable solution. This perfectly suits my own boat and it's use. There is the issue of the voltage drop caused by diodes, but this has never affected me. If the voltage drop was a problem to someone, then there are advanced alternator regulators available that more than overcome the voltage drop losses.
<snip>
You are missing a critical point, using a VSR the batteries are only connected when there is a surplus charge and they do not share the full charge-discharge cycle therefor this is irrelavant, it is not a reason to avoid a VSR. The starter battery will just be idling when the "bad" domestic banks is draining itself. If you wire the VSR correctly it will always make sure the starter battery gets charged before it connects to the other battery bank.
What can I say, have you never heard of exploding batteries, how do you think that happens..
If you have access or want to go and find shore power every few days there is absolutely no point in considering a VSR for a twin engine install. I initially posted to share a possible low cost solution for more charging capacity when you needed it, if you don't then it is sort of pointless..
I have given up on PaulGoosh and will not respond to any of this. I am also not advocating the use of a VSR as neither good or bad however I am concerned when it is dismissed based on ignorance.
One part is what happens at 13.8 volts. The pic below is a diagram of Battery state of charge vs voltage while battery is under charge, the C/5 to C/40 represents different charge currents.
It clearly shows that a battery do not reach 13.8 volt unless its more then 80% charged, in a typical installation it will be 90% charged when it reaches 13.8 volts.
The screen dump is from this document, page 2 http://www.arttec.net/Solar_Mower/4_Electrical/Battery Charging.pdf
A question for anybody to answer. Assume the alternator is producing 14.4 volts o/c and assume the battery is discharged to the extent that the o/c voltage across the terminals is 12.4 volts (an arbitrary figure). Assume that any wiring between the alternator o/p and the battery terminals is zero resistance.
What happens to the voltage across the battery terminals and alternator when they are connected? There is no load on the battery - the only connection is between the alternator and the battery.
Have a made a false assumption with the zero resistance (OK, it would be something due to the wiring but it would be low) - is there something that has to sit between the two?
Next question - what voltage is the alternator sensing between (i.e. the voltage difference between which two points)?
