Charger/Shorepower Unit.... mounting in engine compartment?
jimbouy
21 Aug 2003
Sailing.. Solent. Home..Bucks
I have a combined shorepower/battery charger unit to fit. I've been wondering about a suitable location.
There's a lovely suitable spot in the engine compartment ideally located for the required cable runs.
Is there any reason NOT to mount it here. The only point of any relevance that I can think of is that the unit does require some ventilation. But the compartment obviously lets enough air in for the engine to "breath"
regards
Jimbouy.
fireball
15 Nov 2004
Only issues I can think of are:
Dirt in the engine compartment (oil/soot) that might get into the unit
Heat produced by the engine - might cook the components or cause early failure
Neither are definates - it depends on your engine and engine bay!
stretch33
20 Jan 2002
Essex
Hiya Jimbouy, Had exactly the same issue when l fitted mine, ended up putting in the engine compartment after looking at various other places, in the end it was the most practible place to put it, dry, easy access for cable runs etc. Mine seems to work/run fine and hasnt been a problem at all.
Phil
Anthony
8 Sep 2003
Western Australia
depends on heat, I have a 20A sterling, currently mounted under nav table in free air, and in summer will run the fan quite a bit if I have lots of lights on etc in marina, or just got back in, I wouldnt want to put it in an even warmer place.
Anthony
philip_stevens
live near Saint Ives, Cornwall.
All my shorepower stuff is within 18" of the engine. Charger, isolator, earth trip, along with charge splitter, winch controller, two batteries, etc.
Never had any problems with them. At least they are all warm and dry.
halcyon
20 Apr 2002
Cornwall
We supplied 1,000's to Sealine that were mounted in the engine bay without a problem.
The only thing to watch is if the unit runs hot under load, when you first turn the engine/engines off, the engine bay will be hot till they cool down. So if you have a fan cooled switch mode unit, you may have problems when you first tie up, and use a lot of power from the unit.
Brian
stretch33
20 Jan 2002
Essex
About the same distance, just about in a line with the gearbox, bolted to bulkhead to left of engine that forms side of quarterberth.
asteven221
6 Jul 2003
My charging system is fitted in the engine compartment of my Fairline. It is original equipment so they obviously think it's okay.
discovery2
18 Dec 2002
Jersey
Mine (a Dolphn 20A charger) is also fitted in the engine compartment approx 18" from the engine. No problems, however an integrated fan runs continually when charging!
David
