Adrianwool
Good day,
This is a question for the engine bright sparks amongst you. I would like to clean out the insert contained within the charge air cooler. The manual suggests this is a sea-water cooled component and the way to proceed is to ensure that seacocks are closed and to drain the water within through the drain plug on the bottom of the unit. There are connection pipes at the top of the unit which are obviously connected to the raw water supply and to the gearbox for the purpose of cooling. The top to the unit is held on by a number of dome topped 10 mm nuts. Does anyone know if there is enough clearance to undo the domed nuts leaving the pipes in place allowing the top to be removed and the internal tubular cooling insert to be removed for cleaning?
