Daydream believer
Bingo, that must have been what it was.
So you think you are not going nuts after all
Jury is out on that one :encouragement:
Good stuff, thanks to all.
What I would like to trace is a link to something which I am sure I saw, unless I am going nuts. That is:
That boats crossing the main lines of traffic, in that sector, are requested to not impede ships transiting between the two separation zones
There's no such instruction or rule.
If "impede" means 'try not to get run down', makes sense though.
But firstly it doesn’t. And secondly there are no special rules for the passages of water between the separation schemes.
But you knew that anyway....
The rule to avoid collision applies to everyone but I think you knew that too...
So why have you bothered to say so?
People and remarksSo others (who might not have very full knowledge of IRPCS) can see how stupid some remarks are.
IYO of course.
When you get to those mythical Pearly Gates, your boss will sit you in a corner & make you write lines.
"I should have tried harder, not to upset forumites by deploying facts".
..... there are no special rules for the passages of water between the separation schemes.
Charts have it as a recommended traffic lane and note below........................... >
HO Definition:RECOMMENDED TRAFFIC LANE PART. Recommended direction of traffic flow is a traffic flow pattern indicating a recommended directional movement of traffic where it is impractical or unnecessary to adopt an established direction of traffic flow. (IHO Dictionary –S-32).A recommended traffic lane part is an area of a recommended direction of traffic control area within which traffic flow is generally along one bearing.
Aye.
IYO of course.
"I should have tried harder, not to be so bloody arrogant".
Indeed. And your point is? There’s nothing in the note except some common sense about how if you must cross the traffic flow, crossing as close to right angles as you can. (Because that’s the quickest way to cross the traffic flow. ) Certainly nothing about not impeding.
Try justifying why you disobeyed IRPCS to the subsequent court of inquiry on the grounds of a note with a recommendation on the chart.
Not my opinion. And no arrogance in gently pointing out facts. I’m not perfect and never claim to be. I believe that I know one or two things about IRPCS and their practical application in small craft though. All IMHO of course.
I also know that first reaction of being found out for saying something stupid is to attack.
The IRPCS are not carved on stone tablets.
Yes they are, you need absolutely nothing else, everything you'll ever need to know about collision avoidance is in there!
Rule 2 - "The IRPCS are not carved on stone tablets. "
Indeed. And your point is?...........
