RichardS
N/A
I need to change the lower oil / water seals and O-rings on both my Yanmar SD20 shaftdrives this Spring.
I know that the prop / anode assemblies will come apart easily as when I rebuilt them in 2014 I deliberately omitted the Loctite after the fiasco removing them on that occasion!
The only part which might cause removal problems are the drain plugs which have been in place for a several years and have been well painted over with Trilux. I do have the necessary O-rings but it has occured to me that, provided I use a bucket to catch the oil when I undo the two large bolts and pull the shaft out, I could probably just leave the drain plug undisturbed.
I cannot envisage ever needing to remove the drain plug as I will refill the leg with good quality EP gear oil which will not need replacing until the seals start to leak again which I hope will be in another 7 years.
Has anyone done the seal replacement without removing the drain plugs and is there any disadvantage in doing it this way?
All observations gratefully received!
Richard
Richard
