TernVI
It's amazing how little people understand of their engines.Are you sure or am I reading it wrong? Are you saying that if I run the engine at 2000 rpm and motor with the wind at say 6 knots of speed (stw) and then turn the boat against the wind with a drop of speed at 5 knots the consumption will increase? Why? I would expect that only if you increase rpm in order to maintain the 6 knots will increase the consumption.
The marine diesel engine, basic non electronic flaour, has a centrifugal governor which adjusts the fuelling to maintain a set speed.
In neutral it will rev to 3000 and use very little. Add some load, it increases the fuelling to attempt to keep the speed correct.
Diesel engine specs are full of numbers about how accurately it will keep the same rpm when the load changes.
The more headwind, the more power it takes to turn the prop at the same speed (rpm).
