Trevelyan
Hi all,
So I went today to re-bed a chain-plate, only to discover the wood in the deck is rotten. The boat is a seal 22 and the chain plate is the U-bolt through the deck type (i.e. the deck takes all of the load, nothing goes down to hull/a bulkhead). Photo below of the mess I found - the area exposed might not be all of the rotten deck, but I thought I'd stop hacking away and think about it first! Picture below
You can see one of the bolt holes, the slot corresponds to where the two bolts from the U bolt come down (about an inch and a bit apart). Interesting, the plate that goes across the two bolts underneath isn't much bigger than this!
I need to do a repair of this from underneath, as the seal has coloured topsides (difficult to match) and the chain plates sit in 'cut outs' within the top rail which itself is part of the GRP moulded topsides. Any repair from above would be very messy (I think). Photo of a boat here to illustrate (not mine, photo from web)
Underneath, the area of deck which is wood-cored is quite easy to get at. From the picture below, on the outboard edge the wood butts the exterior hull and on inboard edge the two layers of fibreglass encapsulating it curve together to go on upwards to form coachroof etc. I think some or all of the wood would be fairly easy to cut out, but how I do get it strong again, particularly on the outboard edge where -if I cut lots away, there is little horizontal glass to glass up to etc.
I've done a few cosmetic-only GRP repairs, what I'm worried about here is of course getting it strong - any pointers please on how to approach this from underneath please
Cheers,
Trev
Cheers,
Trev
