Murv
Right, having been thoroughly convinced of the usefulness of this now, I'll have a go at repairing it!
Any thoughts on where to start?
There seems to be two (unrelated?) faults:
1) The heading it displays is wrong, by up to 180 degrees. Faulty fluxgate?
2) Even if I input the heading that it thinks it's on, after a few seconds the pump fires up and jams the rudders over to wither port or starboard, runs for a few more seconds, then stops the pump.
The pump is quite noisy, best way of describing it is similar to a loud water pump with a loud thrubbing noise, But, it's mounted on a wooden panel, maybe that's normal? And, it certainly doesn't have any problem pushing the rudders.
Everything powers up OK, there are no error messages. It certainly seems to think it's doing a good job, except it isn't!
The rudder indicator works, although it does appear to be off by a couple of degrees. The manual refers to re-centering it but doesn't tell you how...
Can the compass be recalibrated? again, the manual is of no help with this.
All other functions appear to work just fine (except, of course, for actually steering the thing) and no functions return a fault code.
The unit is obsolete now, if no ideas, is there anybody anyone could recommend to have a look at it?
