Centre plate wire
bbdave
3 Jun 2010
Cockwood
I have a galv. centre plate which has a slot for the which is then raised and lowered by a winch at the moment the wire is stainless I would prefer to use galv to save risk of corrosion but as it will need a soft eye will the galv just crack off when under tension? Or is there an alternative to wire?
Dave
Have you thought about using Dyneema instead of wire. It is stronger, won't rot and is easier to handle. I replace the lift wire on my boat with Dyneema and it's great
Dyneema is being used increasingly for this sort of application; personally I'd worry about chafe, what about barnacles in the keel slot & casing ?
With stainless wire on a winch, beware s.s. doesn't like tight radii; the Anderson 22 ( vertical lift ) keel winch uses galvanised wire, though some people mistakenly fit stainess ' cos' it's the best '...
aren't there some worries about stainless wire in sea water ? Oxygen deprivation ?
My Stag uses 7x19 stainless on the keel lifting winch. It has a swaged fork on the end which attaches to the plate with a clevis pin. When withdrawn the cable is not in the water so I don't think corrosion is a major factor unless the plate were left in the down position.
I use galvanised wire on my E-boat. It is removed after lowering and locking down the keel, so it doesnt sit in the water all summer. It has a worm driven drum winch under the deck in the forecabin that houses the wire, and is galvanised wire, as I already knew about the problems associated with stainless.
I would however, have used SS if there was nothing else available locally for the "right price".....;)
I would prefer galv to ss as it would be galv to galv contact the joint is clear of the water whilst on the mooring just lowered for sailing I just want to prevent any corrosion before it starts the centre plate is around 8mm thick so I guess there would be no problem with it possibly cutting dyneema? And what knot would be best for a soft eye?
Just to add we have a very high ss to galv corrosion due to the high mineral content in the water.
Dave
I might use a 12-braid dyneema and splice it.
I would cover the wearing part in heatshrink.
Maybe even line the hole with a plastic bush or fairlead?
Or if the lift wire can be shackled on, maybe the shackle can be insulated using a plastic bush?
I think I only have room for tying a knot but I guess a tucked blood knot will be good I use it for tying hooks to fishing line I will make a couple out of Dyneema to try as its cheep and I can replace it easily so any wear can be caught early I can pop in a safety line to just in case.
Dave
