GSL
As far as I am aware, you might get away with a non cert boat in the UK, but if you take it over the channel, you have a very high probability of the locals asking for the CE mark when they are checking your customs/VAT/anything else docs. They are far more parochial about protecting their local industries than the UK!
Trading Stds are supposed to police this reg in the UK, but will probably complain that they are not properly funded. Hence they visit shows and trade fairs as you can hit many suppliers in a short time.
CEProof can do the hull and fittings bit of the CE marking, but I am not sure if they can do the exhaust emissions and pass by noise bits. You might get lucky if the engine manufacturer already has the approval docs, but it is a risk, and very expensive to do. circa £10-£20 k for the emissions, if you can get the engine out and into a emissions lab, and probably £1k ish for the pass-by noise, if you can get a dry and windfree day.
CE Proof did the pass by noise tests on my boat along with other "handling" tests, the emmisions were covered by documents they already had on file as the engines I had (Cat 350TA) had already been tested and found compliant. I had checked prior to buying the boat that the engines would be OK.
Graham
