Coppershield
Fellow boat owners,
for a number of years I wanted to post a caution regarding Yanmar engine oil leaks from bonjo connectors. I'm not sure if the bonjo is the right term nor the right spelling, it is the one were the bolt which is hollow and goes true O shaped connector that makes up the right angle connection. After reading the post from "ShipWoofy" on another post it reminded me to make this post.
This is a caution on an engine otherwise it is excellent product. Just over three years ago engine started leaking oil suddenly and it could not be stopped with tightening of the bolt, I was lucky this happened in port.
If You have this kind of connectors You may want to have some spares on hand.
And if your engine is reasonably new, You may consider doing something about it so this will not happen to You in the wrong place and the wrong time. There are number of ways to remedy this but perhaps the easiest will be to smear wheel bearing grease were the copper washers meeting the other material. Combined with moist environment causing the galvanic activity and rusting the mating surfaces in turn expanded rust makes it nearly impossible to seal it.
Without resurfacing the mating parts, I am sure once You know the problem exists, You will come up with contingency plans.
Best regards /forums/images/graemlins/smile.gif
Muzaffer
Muzaffer
