noelex
Here are some examples where fellow cruisers have anchored in smooth rock. This type of substrate is dangerous as the anchor can develop quite high levels of grip if it snags into a fissure, but with a slight change in the direction of pull the anchor can break free and drag very rapidly. Also the chain or anchor can become stuck.
Unfortunately this is the one type of substrate that a larger anchor does not offer any more security.
It can be a difficult substrate to pick even in clear water, as looks not dissimilar to sand. The best indication is the anchor behaviour when dropped. The anchor will take longer to set than normal. This is just one reason why anchors that set in short distance are helpful - the change in behaviour is obvious. The other giveaway is vibration/rumbling from the chain as it is dragged along the rock. This can be heard (as a rumble), seen (the chain will vibrate) and felt (if you put your foot on the chain the vibration can be felt).
