Rohorn
Hi.....In a previous rambling post a few months back I was aking about hydraulic steering for my Dean cat, and I'm moving forward on that project. However, I'd like to ask you cat enthusiasts about setting up the "toe in" or "toe out" of your rudders.
My existing archaic steering mechanism drives the port tiller. A tiller bar with metal u/j's at the ends links to the starboard tiller. There's a sort of Ackerman geometry, i.e, the outer rudder, in a curve, cuts a shallower angle than the inner.
I'm nerving myself to run a test with the tiller bar disconnected. This would leave the starboard rudder to follow the flow with least resistance. Could I assume this to be the correct setting to reconnect the tiller bar?.
Also, if when steering like this under varying conditions of sail, and power, this setting changes, I propose changing those metal u/j's for flexible rubber joints such as those used at the bottom of some windsurfer masts. This would allow the rudders some relative movement to find their most comfortable "toe-in" setting automatically under any conditions, and hence reduce drag. Has anyone else tried this?
Polite comments appreciated.
Cheers.....R
Cheers.....R
