srm
Its difficult to generalise: which design of monohull verses which catamaran? In either case are we considering cruising or racing designs and how are they being sailed?
I seem to remember reading that the early IOR rule vessels had a propensity to capsize as the rating rules penalised ballast in the proper place - as low as possible. Very many years ago YM published an article about stability. An irate reader wrote in (remember - letters) complaining that his new modern design boat had a worse stability rating than a much older design and build. He presumably felt that newer should equal better.
Likewise catamarans come in all sorts of hull shapes and sizes. A typical catamaran curve of static stability tends to show the angle of vanishing stability around 45 degrees. Yet I have experienced a cruising catamaran at 45 degrees with both hulls in the water and surfing sideways as a breaking wave passed under it. It had V shaped hulls and no boards or keel. I know the angle as it had a clinometer on the cockpit bulkhead (previous owner was a senior naval officer) that was right in front of me as I ducked and hung on expecting the wave to break over us.
Which brings up the difference between static stability, where one can draw nice graphs and calculate angles of vanishing stability, and dynamic stability which is what matters at sea and is difficult to calculate as the varying dynamic forces of wind and waves have to be considered.
When I was actively interested in catamarans (I have owned two, both sedate cruising designs) I had the impression from a number of sources that it was good practice to have the leeward board up to prevent tripping.
Should the windward dagger board be down to act as drag and therefore stability leaving the leward dagger but up. Certainly in my opinion if the leeward dagger board was down with the windward dagger board up, then the cat will trip over its dagger board.
